CST 8" Lift with 37s
Old Mar 30, 2006 | 08:03 PM
  #46
crand002's Avatar
Originally Posted by ThumperMX113
Im not argueing that CST is one of the best lifts but why use a spacer!? I was going to go with the CST lift until I stumbled upon the spacer. Im sure its a good lift but come on. . for the price of the lift it should come with coilovers.
The spacer is for the "econmic lift", which really isn't cheap at all, you can choose from Race Runner, Fox, or King coilovers as a replacement for the spacer at an extra cost similar to what the other lifts do only at a much greater price.
Old Mar 30, 2006 | 08:05 PM
  #47
ThumperMX113's Avatar
Originally Posted by Silver05
Since you know how to work on your own truck just purchase a larger rear block.They don't cost that much. Let me ask you this what size block came with yours?
Great idea, too bad he'd have INSANE axle wrap. .
How much extra are the coilovers?
Old Mar 30, 2006 | 08:29 PM
  #48
Ayresusn's Avatar
Originally Posted by Ayresusn
BTW Fabtech also relocates the steering rack to maintain factory settings, Rancho might also but I'm not sure.
I was wrong the rack just gets extra brackets but it is not relocated.
Old Mar 30, 2006 | 08:31 PM
  #49
Directly from Rancho's website. .
Rancho's heavy duty extended cast ductile iron steering knuckle maintains optimal steering geometry and allows for precision alignment. Steering integrity is uncompromised by maintaining the stock location of the factory rack and pinion steering. Combined these features improve handling and eliminate bump steer. Our exclusive "high clearance one-piece sub-frame" while adding superior strength and stability to the vehicle, precisely relocates the lower control arms and differential. The positioning of the differential is calibrated to correct both CV and drivetrain angles. This ensures a vibration free ride and protects components against premature wear.
Old Mar 30, 2006 | 08:50 PM
  #50
Ayresusn's Avatar
I know, I was just admitting that I was wrong on a previous post.
Old Mar 30, 2006 | 08:59 PM
  #51
I know, I was just stating it for everyone else to see. I wasn't trying to prove you wrong in anyway, just letting everyone else know.
Old Mar 30, 2006 | 09:02 PM
  #52
f150superdave's Avatar
Is 8" of lift enough to drop the diff down enough to clear the frame without having to cut it?
Old Mar 31, 2006 | 01:10 AM
  #53
crand002's Avatar
I could'nt tell you but they have external reso's so probably more than the the Dirt Logics.
