Do BF Goodrich ATs come in 18?
I could have swore they made these for 18" rims, but I checked tire rack and it says they come in 14, 15, 16, 16.5 and 17" wheel diameters. There is no mention of 18. AM I out of luck and just have to select a different one? Thanks
http://www.tirerack.com/tires/tires....White+Letters&
I think you should check that Tirerack link a little bit closer, because if you click on "sizes and pricing", you'll see that they do come in 18"! although not exactly stock size, 285/65/18. Several members on here have those tires.
Both of these tires are made in our stock size 275/65/18 http://www.tirerack.com/tires/Compar...t=All&x=75&y=8
Thanks I finally found the 18" ones, but unfortunately they are on backorder.
Here's a second question. I am also considering the Nitto Terra Grapler 325/60R18 from Wheels for Less (states they are in stock). The website says they will fit a 2004 and newer F-150 with a 2" leveling kit if the wheel has a 5" backspace. Doesn't say whether that's a 4X4 or 4X2 with a 2" leveling kit, but it's only a 33.4" tire so I am assuming it will fit my truck once I install my recently purchased 2.5" leveling kit. What I don't know is about the 5" backspace. I currently have 265/60R18's on my truck right now so now sure how to determine the backspace.
http://www.wheelsforless.com/Ford/default.htm
Any and all help is appreciated. Thanks in advance.
Stock wheels on and 04 up that are 7.5" wide and have 5.5" of backspacing. If you stay with stock you will be okay. If you go aftermarket, make sure they have 5.5" of back spacing, or the wheel will stick out farther.
That's for a 18x9 inch wheel? The stock wheels are only 7.5" wide... are you using aftermarket wheels?
So if I currently have 265/60R18's on my truck on this is on the stock 7.5" wide rims and according to Baja this is for a 18X9 inch wheel does that mean I can easily fit the Nitto TG 325/60R18 on my truck with no issues? I read an earlier post that Nitto doesn't recommend putting that size tire on the 7.5" rims. Thanks for the continued feedback and I know it's going to look good when done.
