F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   APC LED's.... (https://www.f150online.com/forums/2004-2008-f-150/234116-apc-leds.html)
04procompLARIAT Mar 25, 2006 02:47 AM
APC LED's....
are HORRIBLE!!! i had them on for exactly a week and my left light is OUT! yess! but it flickers on when i punch them so i guessing there is a loose connection inside somewhere. anyone fixed these before or had the same problem as i have?
Beefullo Mar 25, 2006 04:11 AM
I know a way to fix your problem:
Never buy another APC product again.
AirborneRacer Mar 25, 2006 06:21 AM
Yeah I tried some APCs on my Ranger. Did not fit right and was not impressed with the quality. Just felt cheap. I won't but APC anything anymore.
Sometimes we just have to learn lessons the hard way. Better luck next go around man.
bobfawcett Mar 25, 2006 06:25 AM
I bought a set from a fellow forum member and he gave me an awesome deal but same problem.One line is out on the drivers side.Since I got them so cheap I am planning on opening them up with my dremel on the backside to see if I can fix them later today.I will post the results.
Bob
Indiana-red4x4 Mar 25, 2006 11:09 AM
I had the same problem. Good luck with APC. They could care less about there customers. Horrible customer service. Hopefully you can send them back for a refund.
bobfawcett Mar 25, 2006 01:40 PM
HaHa!Don't think I'll be sending them back Grant since I just bought them from you!:lol:
bobfawcett Mar 25, 2006 01:46 PM
Ok.If you don't mind cutting the inside of your light they are easy to fix.APC or China I should say put a coating on the back of the LED boards to probably waterproof them but it is conductive.Mine had it across the contacts and I carefully scraped it out from between the contacts and now they work great!!I cut it open with a thin saw blade on my Dremel and when I was done I siliconed the cutout piece back in place.Good as new!!If I knew how to add photos here I would.
Bob
04procompLARIAT Mar 25, 2006 02:18 PM
problem solved! as you know the APC's come with their own plug that plugs into the stock plug on one side and the LED's on the other side. All i did was put my stock plug into the lights and they work fine!
bobfawcett Mar 25, 2006 02:31 PM
Does anyone know what the external black box is supposed to do?It does'nt seem to make a difference if it is plugged in or not.
Bob
