F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   List of TSB's part 2 (https://www.f150online.com/forums/2004-2008-f-150/227934-list-tsbs-part-2-a.html)
mkinttrim Feb 6, 2006 11:25 PM
Make : FORD Model : F-150 Year : 2005
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Num : 18724 Date of Bulletin: JUL 01, 2005
NHTSA Item Number: 10017861
Component: SERVICE BRAKES, HYDRAULIC:PEDALS AND LINKAGES
Summary:
A LOW BRAKE PEDAL. *TT
Service Bulletin Num : 04221 Date of Bulletin: JUN 07, 2005
NHTSA Item Number: 10013393
Component: ENGINE AND ENGINE COOLING
Summary:
MALFUNCTION INDICATOR LAMP ON WITH MISFIRE DTC'S SPARK KNOCK PISTON SCUFFING. *EH VEHICLES BUILT THROUGH 4/25/2005 - 5.4L 3V ENGINE. *TT
Service Bulletin Num : 051012 Date of Bulletin: JUN 07, 2005
NHTSA Item Number: 10017933
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
HARSH 3-2 DOWNSHIFT BETWEEN 17-25 MPH (27-40 KM/H) - NO DTCS - 4R75E AUTOMATIC TRANSMISSION - VEHICLES BUILT BEFORE 4/20/2005. *TT
Service Bulletin Num : 05102 Date of Bulletin: JUN 07, 2005
NHTSA Item Number: 10017935
Summary:
MALFUNCTION INDICATOR LAMP (MIL) ON AND/OR VARIOUS DRIVEABILITY CONDITIONS - 5.4L 3-VALVE ENGINE - VEHICLES BUILT BEFORE 4/20/2005. *TT
Service Bulletin Num : 05923 Date of Bulletin: JUN 07, 2005
NHTSA Item Number: 10017937
Component: STEERING:COLUMN
Summary:
STEERING COLUMN RATTLE/CLUNKING WHILE DRIVING OVER ROUGH SURFACES AND WHEN TURNING THE steering wheel. *TT
Service Bulletin Num : 18678 Date of Bulletin: JUN 01, 2005
NHTSA Item Number: 10017872
Summary:
REPEAT BRAKE SHUDDER/VIBRATION FROM THE FRONT BRAKES WHEN BRAKING. *TT
Service Bulletin Num : 04147 Date of Bulletin: JUN 01, 2005
NHTSA Item Number: 10017923
Component: ELECTRICAL SYSTEM:WIRING
Summary:
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS. *TT
Service Bulletin Num : 18560 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10017880
Component: PARKING BRAKE
Summary:
PARK BRAKE DRAG ISSUE THAT PRESENTS ITSELF AS A VEHICLE SHUDDER TO THE CUSTOMER. *TT
Service Bulletin Num : 050502 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10017890
Component: suspension
Summary:
FRONT END SHUDDER/VIBRATION WHEN BRAKING - VEHICLES BUILT BEFORE 11/18/2004. *TT
Service Bulletin Num : 05618 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10017892
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
rear axle NOISE REPAIR. *TT
Service Bulletin Num : 05132 Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10016845
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P0340 AND OR P0344-5.4 3V ENGINE. *SC
Service Bulletin Num : 031404 Date of Bulletin: AUG 23, 2004
NHTSA Item Number: 10011162
Summary:
ENGINE MISFIRE OR RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS. TO INCLUDE VARIOUS 2005 MODELS. * AR
