Front door speaker covers.
Anyone know where i can buy replacement covers for my from speakers? Other than the dealer of course. I have removed mine a few times and now most of the plastic clips have snapped of and I am getting vibrations with heavy bass.
Did you look on ebay?
JB Weld...I busted a tab off my install kit and a bottom trim piece under the dash...JB welded those suckers right back on. :thumbsup:
I checked ebay and didnt see anything.
Im better off getting new ones anyway. Used ones would more than likely be cracked up like mine are. Im gonna check with the dealer and see how much they want. I am afraid to see :rocker: |
just go to a dealership at night! :devil:
:angel: j/k |
https://fordparts.com/oecatalog.html
has them, there are two kinds so you will have to take a look. They are not all that expensive. Chris |
THANKS Chris~~~~
Much cheaper than I expected $7.17 each. I am shocked they are so inexpensive :beers: :bandito: |
Great find; i also am in need of these. Any idea on which ones are matched to the right interior? I have an xlt with the gray cover. Which one would that be? The flint, pebble, or the steel. I am thinking it's the flint but just wanted to confirm. Thanks
I ordered mine from Fordpartsnetwork. They work about 8 bucks each but when I got them they were the ones without the tweeter holes or cut out for door armrests so they were useless. If you order make sure you specify exactly what you need. I did and still ended up throwing them away.
Using the VIN they sent us the right ones every time. The ones for the Supercrew with the tweeters cost us 14.00 each. The ones for the XL-STX cost 7 bucks, even though they are bigger. |
I have an xlt and I have the tweeter holes and have tweeters in there. The speaker cover wouldnt have a tweeter cutout would it unless it's on the inside of the cover? If so do i need the ones that are 18 bucks? Thanks Chris
The cover itself has little holes (like the holes for the speaker)for the tweater on the models that might option the audiophile.
The ones for the FX4 Crew had the little holes. The ones for the STX did not have the holes. The holes are not needed unless you run tweeters, but I suspect the XLT will have the little holes. Get your Vin number, and call Titus Ford. Or you can always call your local ford dealer and they will give you the part number and a price, then search using the number at the website. Web prices will usually be lower, but there is shipping. On the other hand, there is seldom tax. For me, online is almost always a lot better. Chris |
