Steering Stabilizers for non lifted trucks.
Originally Posted by Screw2004
#15 04-02-2005, 06:28 AM
yob2kanobe
Senior Member Join Date: Aug 2004
Vehicle: 2004 Ford F1fiddy YELLOW FX4
Yes.
The stabilizers wont work with the sock wheel backspacing, however a non lifted truck with aftermarket wheels having 5" backspacing will work, otherwise the bracket hits the wheel.
yob2kanobe
View Public Profile
Send email to yob2kanobe
Find all posts by yob2kanobe
Add yob2kanobe to Your Buddy List
Sponsored Links
yob2kanobe
Yes.
yob2kanobe
View Public Profile
Sponsored Links
Hey! I resemble that remark.
These stabilzers are good you guys, try a set -they only like $75, same as a tank of gas,lol
I have the lift with them but have helped 2 others install this mod on the nonlifted with the offset wheels. It does seem to help the nibble thing some.
if not,You can always take em back off and sell em on ebay
where did you find them for $141? I'm tempted to put the stock wheels back on to see if I have the nibble with them. I have read a few post about an updated rack in later model trucks. My truck has an early 04 build date.
I didn't have the nibble with stock bfgoodrich tires on, but as soon as I installed 33 inch **** cepek tires it started. I then switched back to the stock tires for the winter and it went away. Seem to be very sensitive to different types of road surface and aggressive tires. This spring when I put the bigger tires back on I'm going to try and put on the stabilizer. Has anyone ever changed out the power steering fluid to a different type like lucas or something. Sometimes stock oils are very thin. Sorry if this is a stupid question.
Well just got done getting that fabtec twin steering stabilizer installed,
on a none lifted 4x4
And it did get ride of the shakes It was about 3 hour install had to drill new holes on the brackets that bolt to the tie rod 1.5 inches lower and the trim of about 2 inches off of each one
also you could run stock tires and rims with this set up will post pic's
Screw2004
How hard do you think the installation would be on my truck?
and how much did you end up paying if you don't mind me asking?
Originally Posted by ThumperMX113
http://www.rockymountainsusp.com/
Screw2004
Screw2004
It will be easy on your truck maybe take you 45 min 1 hr.
kit was $153.04 + Install was $200.00 =$353.04
Originally Posted by ptownfire
Does anyone know if they make steering stabilizers for non lifted trucks. I found a fabtech product but its only for use with there 6in lift. And yes I did a search but found nothing.
