Pure Synthetic oil in 2004 f150?
That's what I have been running since day 1. I use the fairly new Mobil 1 5w-20 made for Fords and other stuff that requires that viscosity. I am at 20K now and haven't had the first problem. I usually change it every 5K just because I like to, but I know you can go longer on syn. I usually have to add a quart between changes, but that is typically normal from a synthetic oil due to the way it works. The Benz's at work use a little between changes and they all run Mobil 1.
I was in EXTREME hurry today and dropped it off at Firestone here in pickerington, ohio and they use Kramer oil...they put in GT-1 pure sythetic oil...is this good oil...i would of liked to go with penzoil pure but i was in so muhc hurry i couldn't run to ricart and have them put in pennzoil or motorcraft...will it be ok to change to penn or motor in 3000-5000 miles? thanks
on
Some folks think too hard about oil. You probably aren't gonna see a big enough practical difference to warrant running some high dollar full synthetic oil, but it's your barbeque.
Run something with the latest API rating. Use a good filter (FL820S, IMO). Change it regularly. Sleep well at night.
Originally Posted by SoundPer4mance
i use amsoil
scorpio, i am a dealer, so for any truck that wants 5w20 ill reccommend 5w30 or 0w30. Amsoil does have the XL Series oil in a 5w20, but IMO its overpriced for what it is. I wouldnt be suprised though if in the near future they came out with a GOOD synthetic 5w20. The demand is just too high for them not to.
Everyone has their own oil oppinions...I would like to see two Ford 5.4L modular engines side by side after 100K miles, one with fully synthetic, one with the synthetic blend Motorcraft stuff.....tear them down and look at wear....
If there was no difference, I would be convinced there was no advantage to fully-synthetic oil beyond being able to run it longer in the engine...
Until then, my piece of mind comes from Mobil 1 5w-20 fully synthetic.......
I run syn in mine only because it is really hot where I live. City driving in a place like Phoenix at 110' makes for some unreal underhood temps. I usually see a 30-40' difference in the outside temp and the intake air temp in the summer. With all that said, check out this link, You'll find it sums up what Quintin says.
http://www.nordicgroup.us/oil.htm#Th...%20Mile%20Myth
