Dissapointment in the Screw
Old Oct 29, 2005 | 10:35 PM
  #31
Texas F-150's Avatar
E=M....C.....wait, what was the question?
Problem with trying to pull posts out, either from the top or the bottom, is you're pulling in a direction 90 degrees from the way the post wants to come out. An easier and safer way to do this is to get an old steel rim from any number of sources, trucks, trailers, etc....and put that next to the post. Hook onto the post at the base and then to the truck, using the rim as a pivot point for the strap/chain. When you pull the rim acts as a pivot and exerts a vertical force on the post and pulls it out of the hole. In addition, should the chain snap it'll shoot up and not back towards your truck, although I always use a strap for extra safety.
Just a thought if you're determined to get that post out.
Old Oct 29, 2005 | 11:35 PM
  #32
shookman34's Avatar
That sounds like a neat idea...are you talking about setting the rim so that it is standing up or laying on it's side???
Old Oct 29, 2005 | 11:57 PM
  #33
efexfour's Avatar
Thank goodness the boat wasn't buried in the dirt!
Old Oct 30, 2005 | 12:34 AM
  #34
SteveVFX4's Avatar
Originally Posted by Sick05Lariat
death is no laughing matter.
granted, this guy was trying to pull something a little bigger than fence posts, but read this: http://www.msha.gov/fatals/2003/fab03c24.htm
Old Oct 30, 2005 | 12:38 AM
  #35
ThumperMX113's Avatar
Hmm . . .
My SCREW amazes me every day!
  #36
GordoPanocho's Avatar
Registered User
"You might be a redneck if ..."
Old Oct 30, 2005 | 12:45 AM
  #37
Standing up. Of course this will only work on posts that are a reasonable size. Like Steve mentioned there, some things are just common sense.
Old Oct 30, 2005 | 06:23 PM
  #38
Grim's Avatar
I prefer the bucket on a front end loader and a bit of chain
If you can't get that, a high-lift jack often works.
Grim
