PCM Update for Trucks built before 5/13/2005
Originally Posted by Quintin
It's impossible to say what the latest calibration is without actually trying to reprogram the PCM, since some trucks may have different calibrations depending on build date. For mine at least, an April '04 build 5.4 3V Supercab, the latest available is 4U7A-12A650-GPA. This may apply to some other trucks built around the same date, I dunno.
can anyone tell me if there a update or a way to find out a update on reflash for built date of aug.05 i have bad thottle responce and bad fuel milage and rough idle ,dealer said no updates and is normal for the 5.4 engine crew cab,thanks
Originally Posted by ceril
just called my dealer im getting this done this saturday at 9 am.. hopefully itll wake my truck up as well. thanks for the info guys.,
Originally Posted by bluejay432000
Good luck, when mine was done, their computer locked up and they had to keep my truck over night(from Sat till Mon) till they could get an upgrade from Ford. Had to give me a loaner, but it was worth the hassle. All the difference in the world, like a different truck.
knowing my luck it will happen to me too BUT if it does what you say it should be worth it
My 05 screw 4X4 had the reflash today and it was an amazing difference.
no more clunk and better throttle response
build date was feb 05.
I wish they could just get rid of the road vibration thru the steering wheel.
They did road force balance today no change.
Regards!
Originally Posted by kcward
Mine too! Build date of 7/05. Crappy gas mileage 10-11 mpg, and it boggs down in turns...Dealer wouldn't re-flash. I pointed out the re-flash for the 04's and that is what he said "it pertains to the 04 and not the 05".
Regards!
Regards!
I made an appointment for Friday at my dealership (my build date is 4/4/05, and my truck has all the symptoms addressed by the TSB). Unfortunately, I got the sense from the service writer that Ford is making it tougher for dealerships to justify the reflash as warranty work.
You have to have the TSB with you, but first complain of the exact items that are on the TSB. Also, I found it helps if this is your second request for a reflash, to go to another dealership. They are EXTREMELY difficult to get a reflash out of under warranty. Supposeably it is because Ford is making it difficult to claim that warranty work.
Regards!
Regards!
The key is to complain. Ford won't fix it unless there is a problem that you have with it. I told them that there was no take off, a lck of throttle response when passing at around 25mph and 55mph. I also said there was such a bad lag during shifting I would actually loose speed. All this pretty much was true, just not as bad as I made it sound. After the update, it was like a new truck. Better gas mileage too, and the exguast was louder also. I have a 05 5.4L with a build date of 03/05. The sticker that the dealer put under the hood was:
PCM Reprogrammed: 5L3A-12A650-C1B
TSB AUTHORITY: 05-10-02
I complained about the lag when trying to pass another vehicle. Told the service manager that it was going to get me killed. He jumped right on it.
