burn mobil one oil off ? normal ?
hi,
I changed the oil at 12,500 5w-20 mobil one (w/ motorcraft oil fliter and i just checked the oil dip stick, it drops to half between low and high mark at 16,200.
is this normal for mobil oil to burn some oil off and it show a bit tan color on dipstick??
Its 5.4L 2004 F150
Am i parniod for nothing ??
Thanks!
YOMAN!
Its 5.4L 2004 F150
Thanks!
YOMAN!
I had a 99 F150 5.4 always used synthetic oils mostly Mobil 1 in the 102,000 miles put on it the Mobil 1 always used 1/2-3/4 quart between changes at 5000 miles intervals. I have a 2004 now and planning on running motorcraft from now on.
I use Mobil 1 in both my trucks, it has never burned any oil. I change every 3k and it is always at the top mark on the dip stick.
I wouldn't be too conerned, just keep an eye on it and make sure you don't have a leak. Check where you park and make sure there aren't oil stains.
There is mucho oil info at http://www.bobistheoilguy.com/
IMO it is hard to beat Motorcraft 5w20 with FL820S Filter.
TW
TW
I put 188,000 miles on my 2001 F150 4X4 SuperCrew using Mobil 1.
Changed the oil every 5,000 miles and never lost or burned off any oil.
Check for leaks and/or tighten your oil filter.
nordicbastard
