3" Skyjacker with 285/70/17's
Hello Everyone
I have an 04 Scab FX4 and i was thinking of going with the skyjacker kit and running 285/70/17's with some aftermarket wheels. I was wondering if any of you think this size of tire is too small. I dont want a wide tire, because they seem to push snow instead of plow through it. Any comments would be great Thanks :beers: |
yes the tire is too small, alot of people are running 35's with just a level kit, including my self. check out my gallery
Not with different wheels they arn't. I'd say 33s and the 3" Skyjacker would look fine and if you could fit 35s than do it! :thumbsup:
That's pretty much the same size as the stock tires. A 3" lift with stock tires would look pretty silly IMO, but that's just my opinion. It's your truck. If you want a skinny tire, that's fine, but atleast get a bigger diameter.
I believe the Truxxx website has a three inch level kit and 285's which is a 33 inch tire, even a 325/60/18 is only a half an inch larger...correct?
I have got a 2 inch leveling kit and 285/70/17 MT/R's by Goodyear. They also make a 305/70/17 which is a little bit bigger and wider. I would go for a bigger tire.. they even look a little small on my truck.
https://www.f150online.com/galleries...532-136336.jpg |
hey black2004fx4
your truck looks shiny did you wax it? if so what kind of wax did you use? back to the topic.. I just have the leveling kit and running 33x12.5 pro comps on 17x10 inch rims. if your going to get the 3 inch lift go 35's or close to it. not sure how wide your going to go or if your going to use stock rims. just my 2 cents |
I agree with OMC. If you're going through the trouble and $$$ for a 3", go 35's. My SC is stock and I have 33's with tons of room! So, leave it be and get 33's (285's) or reach for the sky! :angel:
Dan |
All i know is that is what skyjacker recommends is a 33" tire. Also a 285 is the skinniest you can go without going to a 12.50.
| All times are GMT -4. The time now is 08:52 PM. |
