F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   20's gas milage (https://www.f150online.com/forums/2004-2008-f-150/209326-20s-gas-milage.html)
00_offroad Aug 24, 2005 06:53 PM
20's gas milage
For those rolling on 20's did your gas milage go down when you put them on and if so by how much? Also if anyone has them that tows can you notice a difference in power? (pulling) I have been told it will kind of change my gear ratio. Just trying to get some advice for when I get my truck back.
TCC- Aug 24, 2005 08:17 PM
I tow a 24' Baja, 5k with trailer and mine does fine. I've got 20's, I don't know how much the MPG went down because I put the wheels/tires on when the truck was new..
dzervit Aug 24, 2005 09:10 PM
Wheels don't change the ratios... the overal tire diameter does. If your rollin' on 16s with a 30-inch tire that's the same as rollin' on 20 with a 30-inch tire.. just a lot less sidewall. Get it? It's all about the diameter of the tire, not wheel...
00_offroad Aug 24, 2005 09:20 PM
Thinks for that I get it. What kind of gas milage do you get with the 20's?
JJG052590 Aug 24, 2005 09:23 PM
Probably the same depending on the ratio of the tire... Different people get different gas mileage on how hard they drive it what size tire what alot of stuff makes differences..
dzervit Aug 24, 2005 09:28 PM
I don't have 20s yet. But here's the other secret.. the real killer to the MPGs is the weight of the wheel/tire combo... Read this and learn a bunch..
http://www.tirerack.com/wheels/tech/...jsp?techid=108
00_offroad Aug 24, 2005 10:17 PM
thats great something else to marinade on.. anyone happen to know what the 18" fx4 wheels weigh?
dzervit Aug 24, 2005 10:28 PM
That's info I don't have... I also need the wieght of the 18" lariat wheels. :lol:
LsuSuperCrew Aug 25, 2005 12:36 AM
That was a great write up, but it still showed that the stock tires and wheels got the best mpg. Even the lightweight wheels couldn't get the same mpg as the stock wheels.
Intel486 Aug 25, 2005 01:09 AM
Weight causes change. Rotational inertia baby.
h8louzn Sep 9, 2005 12:28 PM
On my 03 I lost about 1-2 mpg. I used a 295/45/20 to replace my 265/70/17's..
Hope that helps ya..
And it is because the new rim/tire combo weight...
RamSS/T Sep 9, 2005 12:44 PM
My 24s weigh about 180lbs each (wheel and tire) and I lost about 1.5-2 MPG in the city and pretty much nothing on the road with them. The major reason for the loss of MPG in the city is the energy to get them started rolling...once they are rolling your good to go.
CarlJ Sep 9, 2005 12:50 PM
I lost about .5 mpg with mine. It went from 14 to 13.5 mpg. My new wheels and tires weigh about 80lbs/ea.
fourpointsix Sep 9, 2005 02:22 PM
I went from 15.5 mpg to 13 mpg when I got 20s. Note that I did switch from the stock 30 to a 32 inch tire, and I have 3.55 gears. I'm definetly getting 4.56 gears next. :devil:
bradster Sep 9, 2005 02:30 PM
Probably the biggest factor is the tire width. More rubber = more drag. Get skinny tires!
Although 180 lb wheel/tire combos will also definitely kill your mileage! Holee sh1t RammSST!
I wish BBS made lightweight forged wheels for our trucks! :)
