Back from 9140 mile trip to Alaska, some thoughts.....
Old Aug 23, 2005 | 12:19 PM
J-150's Avatar
Originally Posted by CNS
Don't like the fact that if the cruise is on and you want to get a run at the hill you have to push the pedal through that dead space since the pedal doesn't move with the cruise.
why would you want to do that? The cruise should maintain your speed going up a hill. If you need extra power, turn off the O/D for the incline and then turn back on once you have completed the hill.
Old Aug 23, 2005 | 10:35 PM
salzmann's Avatar
Deja-vu!!
Wow, incredible.
We took a 9300 mile trip this summer with our F150 XLT (not lariat). We averaged 16.8. Best was around 20. Worst was 13.8 (South Dakota, 80mph, headwind). 5.4l engine. Like yours, our speedo is off about the same amount but the odo is right on the money. We also tested it with GPS. Like you, we have commented how the miles went by effortlessly - and we did get to go through some canyon twisties - one of them an accidental offroad experiment that came from trusting the GPS!
Great report of your trip - we enjoyed it. Some think a truck is a funny "family car" but other than a big RV or conversion van, I can't think of a better way to drive cross the country.
Old Aug 24, 2005 | 12:59 PM
CNS's Avatar
CNS
It will maintain going up a hill, but it almost always unlocks the torque converter to do it. I can go up the incline with out it unlocking if I use my foot. I can maintain my speed my speed on a hill without getting a run at the hill and without the torque converter unlocking, the cruise will maintain on a hill but some hills cause the torque converter to unlock which uses more fuel than you would think.
Old Aug 24, 2005 | 01:06 PM
CNS's Avatar
CNS
Originally Posted by salzmann
Wow, incredible.
Sounds like you enjoyed your trip as much as I did! I've made several long distance trips before, none nearly that long, and none of the vehicles were even close to being has comfortable as the truck was!
Old Aug 24, 2005 | 01:27 PM
CNS's Avatar
CNS
Originally Posted by Tical84
If the HU says FL and it played from the front left, wouldn't that mean that it's wired correctly? The only way it couldn't be wired correctly is if the text that comes up on the HU was programmed incorrectly as well. Like if it says FL, plays front left but should really be front right. Seems highly unlikely. Maybe your speakers at home, or wherever you usually listen to that CD are backwards.
The voice on the CD says where in the sound field the voice is coming from. It is an Alpine test CD and it has worked right in everything else I have played it in.
If the output from the CD or radio is wired in reverse into the amplifier in the unit, it would play out of the opposite speaker. The walk around is more than likely just adjusting the amp portion of the head unit. Another example would be if you reverse the RCA jacks coming out of the CD player in your stereo, home or car, and then change your balance on the main unit. It will say left, play out of the left, but will actually be playing the right side of the stereo program. Hope that made sense.
Old Aug 24, 2005 | 01:33 PM
3valve's Avatar
Drove to Alaska by yourself?
Old Aug 24, 2005 | 02:54 PM
CNS's Avatar
CNS
YEP, everyone I know is either married with kids or broke or both....being single has its good and bad moments............
