AC cycling on/off every 10 seconds. Normal?
ac click
hi used to have a 98 lariat that used to do that, when i had it checked, there was a leak at the evaporator, they replaced & it was great. although mine was loosing cooling power, w/c was obvious since I am in the tropics. hope you get to enjoy your ac..this one of the things I truly appreciate bout this truck no matter how hot the ac gets the truck cool & keeps it cool. my ac is on all the time we use the truck
I agree with JCC here. Down here, it's all A/C, all the time. I had mine checked for some pretty regular cycling, and it was full on freon and blowing in the 40s. I then checked it myself (ya can't just trust the dealer, can ya?!) and got nearly the same results.
I'm left with the presumption that perhaps the unit is somewhat underpowered and has to cycle more often.
Originally Posted by mjs
When I run the AC, I hear a loud click every 8 to 10 seconds. It is extremely annoying. Is this normal? MJS
The AC will do this under two different conditions. One is under low load conditions (i.e. Minnesota instead of Arizona.) The compressor switches on and off to prevent the evaporator (the inside part) from freezing solid with condensation. The other condition that causes it to cycle is being low on freon. It's easy to tell the two conditions apart though. Stick a thermometer in the vent. If it is close to the outside temperature, the system is low on freon. If it's close to freezing (like high 30's to mid 40's) it is running just fine.
A higher vent temperature can still be normal, but not if the compressor is cycling.
I, like MANY others on the board, had the same problem. I added a can of "Sub-Zero" freon to it and it not only cycles far less but cools so much better. I checked it before I put the freon in and it was on the low side of acceptable pressure...now its toward the middle of the acceptable range.
My advice is to add a can of freon and see if that doesnt solve the problem.
Originally Posted by Intel486
I'm having the same thing on my new truck. I heard a clicking when I was driving and couldn't figure out what it was and then when I had it in the carport standing outside the clicking was easy to hear.
I'm going to have the dealership take a look at it though
Originally Posted by jcc
cycleing is normall on all vehicles , overcharging it wont solve the problem it all works on pressure if you over charge it your output temp will increase and head presure will go up
I know quite a few people on here have added a can of freon to their trucks and its really helped theirs as well.
