Panel with cig. lighter removal...whats involved?
Originally Posted by CrAz3D
It's just a bunch of fun little clips. Getting the cig lighter out of the panel, though, is not so easy & fun
Chris, did you just cut though the little empty spaces on that panel for your switches? I've been lookin @ putting my fog horn & aux lighting switches there.
Chris
f150newf
You have to remove the radio bezel then disconnect the wire harnesses to the a-c control unit, the cig lighter and then the seat belt on off, if your's is indeed in the bezel. This for me was tough because there was very little slack in the wires and it was difficult to see what I was doing. once you have the bezel free you can unclip the plastic face from the backside and do what you need to do to make the switch work. To remove the bezel just pull from the bottom by the ashtray/cup holder and work the clips loose from the bottom up. I believe there are three clips on each side.
I hope this helps
Scott
I hope this helps
Scott
