Belltech lowering shackle problem
Old Dec 29, 2005 | 06:14 PM
  #31
SoundPer4mance's Avatar
quintin now that you mention it my truck does have a 2pc shaft, i added the eibach pro kit to my truck and took the shim out, now i have the vibe, im going to put the shims back in this weekend and see if it goes away
Old Dec 29, 2005 | 07:05 PM
  #32
Quintin's Avatar
Originally Posted by JazzyJeff
sorry for being ignorant. But the Scab has a two piece driveshaft? I havent looked under there. I drive an 04 Scab. You think I'll have a problem with the driveline vibration? Thanks
Yes, the Supercab has a two piece driveshaft with a center support bearing, at least mine does. I'm pretty sure all 4x2 Supercabs with 6.5' beds do, ones with 5.5' beds might not, but I'm not sure.
Old Jan 19, 2009 | 10:13 PM
  #33
shokher99's Avatar
it might be a stupid question but which way do you angle the axle when you put the shims in? up in front right?
Old Jan 19, 2009 | 10:44 PM
  #34
The thick end of the shims are oriented toward the back of the vehicle.
