Infinity Reference 6810cs
Old Apr 28, 2005 | 06:57 PM
ThumperMX113's Avatar
I was wondering if anybody has these for their truck? I wanna know if there any good and what you think about them?
Old Apr 28, 2005 | 07:29 PM
05RedFX4's Avatar
I thought about buying those speakers myself,let us know what you think of them, if you get them
Old Apr 29, 2005 | 08:20 AM
Crstfr's Avatar
hey thumper.. try this site man.. might save you some cake!..
my buddy has the 6800 series and he loves em
http://www.discountjungle.net/
chris
Old Apr 29, 2005 | 12:55 PM
plester73's Avatar
crstfr,
Thanks for that link...those are some great prices!
Old Apr 29, 2005 | 09:19 PM
takotruckin's Avatar
if you are looking for really good sound i would go with kappa or kappa perfects, reference is pretty much the base model. but i guess all infinitis are good. i love my kappa 12"
Old Apr 29, 2005 | 09:51 PM
Peacemaker's Avatar
I have some older model infinity reference 5752cf 5x7's in my 01'. They have always sounded bright and clear with some pretty good thump. That's with no amp. You should be good without an amp with those particular speakers that you posted because they have a high sensitivity level @ 92 dB. And they handle between 2 to 90 watts, which are in range with your factory radio. But you can add an amp if you want a cleaner sound at higher volumes. Or if you add a sub later, you'll need an amp for the door speakers anyway to keep the sub from drowning them out.
Old Apr 29, 2005 | 10:14 PM
countyboy04's Avatar
Is the DDX7015 powerfull enough to run a set of infinity components without an amp?
Old Apr 29, 2005 | 10:17 PM
asinatra's Avatar
you can fit 6 1/2's in the door if you build your on plate, round speakers sound better, ikesound has some great prices
Old Apr 30, 2005 | 12:14 AM
Peacemaker's Avatar
As long as the head unit puts out enough watts to match the wattage specs on the speakers. The higher the sensitivity (dB level) of the speakers, the more efficient they are. Meaning it takes less watts to power them. Usually anything under 90 dB's needs an amp. Say your head unit makes 22 watts RMS per channel. And your speakers wattage range is between 2 watts to 90 watts. And your dB level on your speakers is 92-93 dB. They are going to play fine. But just say that you use the same head unit, and then try connecting speakers with a dB level of 89 dB, and a wattage range of 8 watts to 98 watts. You aren't going to get good sound out of those speakers because they require more power (in watts), and the have a lower dB sensitivity level which makes them less efficient. Meaning that they require more power (an amp). Is that clear as mud? I hope you get an idea of what I'm trying to say. If you don't, just go to crutchfield.com and get their toll-free number. They can tell you anything you need to know.
Old Apr 30, 2005 | 03:04 AM
hippo's Avatar
so all the speakers are 6x8? so those components would be good for up front, then the two rear could be replaced by some 2 way speakers like these.. reference
looks like a good deal.. ive had the infinity basslink sub for a while and for its size it produces clean bass... i think ill stick to infinity
Old Apr 30, 2005 | 03:10 AM
40/99/04trucks's Avatar
i have the perfects in my 99 and in my 04 f150's cant get much better tweets and mids clean sound and they are very durable.M.W.
Old Apr 30, 2005 | 10:59 AM
Im going to do front and rear components. It really wouldn't be that much more expensive to do and Im sure that it will make the sound a lot crisper.
