dome light rattle
Old Mar 11, 2005 | 12:34 PM
KaNigIt's Avatar
dome light rattle
Well I've had a rattle in coming from the dome light in my reg cab and its driving me nuts! Of course it only rattles when i have my sub when it is its pretty loud. I've tried everything possible to get it to stop. Does anybody else have this rattle or a possible solution?
Old Mar 11, 2005 | 01:01 PM
Buck Henry's Avatar
Not sure of the regular cab set up, but my 04 Supercab with a moonroof had a similar rattle that eminated from the rear dome light area.
If you pull the dome light assemble out and look up into the headliner area, you should see two little foam spacer blocks. In mine, these blocks were the source of the rattle as they would bounce up and down and strike the metal roof. I simply put some additional foam between the blocks and the metal roof to take up the space and the rattle was gone. Hope that helps.
Buck
Atlanta
Old Mar 11, 2005 | 03:33 PM
KaNigIt's Avatar
Ive pulled the cover off , but do you mean the whole thing? If so how do you do it, just yake it out?
Old Mar 11, 2005 | 04:23 PM
jims94vmx's Avatar
i was checking out the position of my light in the back also and noticed it really moved easily (back and forth). had the dealer look at it when doing the ashtray rattle problem and they did the same thing with the foam i believe...it is alot more secure then it was before.....hope this helps. good luck.
Old Mar 11, 2005 | 04:29 PM
Buck Henry's Avatar
You have to pull the light assembly out as well as the cover to look up inside the liner area. It has a couple of plastic tabs holding it up there. Work it out gently, it will come out after a little effort. Again, I am not sure if your roof liner will have these foam blocks, but my Scab did and they were definitely the source of my rattle. Good luck.
Old Mar 11, 2005 | 09:22 PM
KaNigIt's Avatar
alright thanks ill check it out tommorow when i have some light!
Old Mar 15, 2005 | 06:20 PM
KaNigIt's Avatar
just an update..... I couldnt find the foam disks but maybe i wasnt searching enough.... I did however manage to get the light out like you said and was able to some foam between the back of the light and roof and it finally fixed the rattle. THANKS!
Old Mar 15, 2005 | 06:40 PM
MooseRLP's Avatar
you could of done what I did and put a monitor up there with lights on it. Check my gallery
Old Mar 15, 2005 | 06:55 PM
KaNigIt's Avatar
lol.... thats definately a good way to fix a rattle....
Old Mar 15, 2005 | 09:56 PM
Guigster's Avatar
This sounds like it could be the same problem I finally narrowed down in an earlier thread. Of course, I haven't fixed it yet.
