Poor Mans Homelink
The button to the right of the lighter is my garage door opener. Total cost $2.65.
Thanks to Scott7065 for the two hole trim piece https://www.f150online.com/galleries...allery5447.jpg |
Sweet, looks good, wish i could park my truck in my garage, its filled up with quads/dirtbikes.:(
Very cool mod!
Excellent idea! :thumbsup: I miss the built in Garage Door Opener compartment that I had in the overhead of my 2002 Screw.
true dat.
I'm actually gonna stick my garage door opener on the inside of my door map pocket, so I just have to reach down on my left and hit it with my fingers. |
That looks good .How did you do it ?:thumbsup:
That's just way past cool!! Is it still battery powered or are you using a power converter??
The board runs on 3 volts so I put a new battery in, it should last for about two years
jgross must be McGyver! :beers:
How did you know which joints to soldier for the wires?
The controller I used had three buttons. Each button had four post soldered to the board. I put my meter on different post until it showed 3 volts then I pressed the button and the voltage dropped to 0. I used those post.
Originally posted by anaheim Sweet, looks good, wish i could park my truck in my garage, its filled up with quads/dirtbikes.:( |
