yes......another tire question.
Do you know what those tire numbers even mean?
Stock - 255 width
Nittos - 265 width
Wait let me grab my calculator, umm, they are 10 mm wider!
if you don't understand the tire numbers, read this:
http://www.tirerack.com/tires/tirete...nformation.jsp
Stock - 255 width
Nittos - 265 width
yes, it is wider. your stock one is 10.2" wide and the nitto is 10.79" wide. Pretty much you will never see it.
Here this should help:
Tire sizes are normally listed in 3 numbers, such as 205/55/16.
The first number is simply the width of the tire in mm (205 mm).
The second number is sidewall height as a percentage of the width. For instance, in this case, the sidewall is 55% of 205 mm: 112.75 mm.
The third number is the diameter of the wheel (rim) in inches.
ummm....
How many 'tire and wheel' forums do we have here? But it's funny, a day isn't complete until we have at least 2-3 tire threads on this forum every single day. And the sad part is that most of them are identical repeats of the threads from the day before. But I guess people who cannot read yesterday's tire thread need to start today's tire thread- in the wrong forum.
Originally posted by RockyJSquirrel
ummm....
ummm....
I can't see how I was the jackass, I informed you that the tires were 10mm wider, and gave you a website to read about tire number descriptions!
Too lazy to use the search...maybe next time you should use it so you save yourself the embarassment of asking a lame question like is a P265 tire wider than a P255 tire!
