Help me fix this squeak!
On the drivers side of the dash, you know that red light that flashes on and off? Thats why my squeak is coming from! I took some silicone spray the frist time and sparyed it down. That worked for a week. Sprayed it down the week after, and once again it only worked for a week.
Have any ideas on how to permanetly stop that squeak?? |
I have a rattle in the same location. It makes more noise when I'm truning right, but I have never been able to fix it.
I think the only way to fix our problems is to turn up the radio. :rolleyes: |
Originally posted by Fruitcake I have a rattle in the same location. It makes more noise when I'm truning right, but I have never been able to fix it. I think the only way to fix our problems is to turn up the radio. :rolleyes: |
Dude I know what you mean I have a rattle in the front and I will check the light thanks. I cant stand rattles but beware you dont get a stiff frame like our trucks and no rattles.
Shudder on tak off(In turn)
I just noticed this and read the posts on the forum from search. Is this a serious problem that has to get fixed. What would happen If I did not fix it. Just curious.
Re: Shudder on tak off(In turn)
Originally posted by Scubaman I just noticed this and read the posts on the forum from search. Is this a serious problem that has to get fixed. What would happen If I did not fix it. Just curious. |
As for the sqeek at the blinking light, I put baby powder on it and it never came back.
The rattle I was told at the dealer that it was because of the add-on deflectors that I put on. I removed them. Test drove the truck and the rattle is still there. The only place I could come up with from where the rattle is coming from is the windshield trim on the drivers side. If you tap it you can almost reproduce the same sound. Still no fix, I'm working on it.:smoke: |
Originally posted by MRBIG As for the sqeek at the blinking light, I put baby powder on it and it never came back. The rattle I was told at the dealer that it was because of the add-on deflectors that I put on. I removed them. Test drove the truck and the rattle is still there. The only place I could come up with from where the rattle is coming from is the windshield trim on the drivers side. If you tap it you can almost reproduce the same sound. Still no fix, I working on it.:smoke: |
