Ceramic pads that do not dust???
Old Feb 18, 2005 | 07:36 AM
kidtriton's Avatar
and if they do not dust, post which ones, how much, and where to get.
thanks
Old Feb 18, 2005 | 08:33 AM
jztbcz's Avatar
Brake section ...... Brake section ........
with over 1000 posts you should already know that ...
Old Feb 18, 2005 | 08:46 AM
MHK's Avatar
MHK
I just got my F150 3 weeks ago, and I have a dust problem on the front wheels that I need to deal with.
I had an even worse dust problem on my other vehicle and I bought Advance Auto Friction Master ceramic for $50 for front pads. I recommend them. MH
Old Feb 18, 2005 | 08:55 AM
dzervit's Avatar
SEARCH SEARCH SEARCH....
Old Feb 18, 2005 | 10:16 AM
kidtriton's Avatar
OK, almost every post in the past has been when someone was either thinking about buying some, or have just bought and installed them. I am looking for people who have had them for 6 months or so to chime back in and tell us how they have done.
Old Feb 18, 2005 | 10:19 AM
easterisland's Avatar
It takes a lot of effort for a big truck to stop. The brake dust is a sign the brakes are working. If you want an inferior ceramic brake pad be my guest. I almost had a wreck with them on my Lightning and they are hard on the rotors. I will never use ceramic pads again. Give me brake dust.
Old Feb 18, 2005 | 10:28 AM
SteveVFX4's Avatar
although not ceramic, but I've been giving reviews about the Porterfield carbon kevlar pads. Had them since June 04, about 7000 miles or so, and still working great. No dust, rotors seem fine. They started to squeel after a few thousand miles, and I just lubed them up with anti-squeel grease (Napa Disc Brake Quiet) and they have been quiet since.
Old Feb 18, 2005 | 09:24 PM
Guigster's Avatar
How do you apply this stuff? Do you have to take the pads off and put them back on?
Old Feb 19, 2005 | 12:22 AM
SteveVFX4's Avatar
^yes, you have to remove your pads. The Napa stuff is actually a red gooey substance, and you apply it to the outside of your brake pads. You will see if you take yours apart where the caliper grabs the pad and the paint is worn down on the outside of the pad. I spread the gooey stuff all over the pads. You let it "setup" for 10 minutes or so and then reinstall the pads.
After I put my wheels back on, I realized the red stuff really stood out through the open FX4 wheel. So I took my wheels off and just grabbed some black spray paint and sprayed the outside of the pads and caliper with the black paint. Been working great ever since and not a single squeel.
Old Feb 19, 2005 | 01:24 AM
kevhunt's Avatar
I've had ceramics for over 3000 miles now and can say NOTHING bad about them. The dust is almost non existant and the stop this heavy beast just fine. Akebono Proacts for anyone wanting to know...Kevin
Old Feb 19, 2005 | 10:45 AM
khendrix2374's Avatar
I got ceramics on on my front brakes. They stop just as good as the OEM, but the dust is gone.
From what I hear about OEM rotors, I bet the pads will outlast the rotors.
Old Feb 19, 2005 | 12:28 PM
kidtriton's Avatar
I found some Firction Master brand ceramic pads that advance auto sells for 45.00, anyone ever tried these?
