pics of 35's on leveled truck? - 2wd preferably
Old Jan 25, 2005 | 05:38 PM
KaNigIt's Avatar
I know Beaver Tricks used to have this setup but he doesnt have anymore pics before his lift, does anyone else have or seen any? Id like to go with 35 over 33 because first off I can find more of them for cheaper and second because I plan (well at least dream) to get a lift eventually. From what I remember of beavers truck, it didnt look like the tires were that oversized but when i see leveled 4x4's with the same tires it looks like its pushing it so it seems like the 2wd would really be crammed.....
Old Jan 25, 2005 | 07:39 PM
KaNigIt's Avatar
anybody? Man i wish beaver still had his pics.....
Old Jan 25, 2005 | 07:47 PM
powerage's Avatar
Check my gallery. It is 4x4 though. They are 35/12.5/18 Toyo open Country MT's
Old Jan 25, 2005 | 08:55 PM
Scott 7065's Avatar
KaNiGit
I know you wanted 35's but I'm leveled with 285 55 20's which measure 32.5 in diameter since not too many are offering up pics I added mine for the heck of it. just imagine a little more rubber.
Old Jan 25, 2005 | 09:00 PM
Scott 7065's Avatar
KaNiGit
I dug this up for you
Scott
Sorry dude, this is a 6" lift which you already knew.
Old Jan 25, 2005 | 10:07 PM
KaNigIt's Avatar
thanks guys! This gives me a ruff idea... powerage - you rubbing at all with your 4x4? Scott - nice rims first off.... are you rubbing, you think 35" (which are actually have a real diameter of 34 because the ones im looking at are slightly used) would fit? Its kinda hard to tell with pics I guess becomes some look completely different than others, yours doesn tlook crammed at all and still have a *little* bit of room.
Old Jan 25, 2005 | 11:38 PM
powerage's Avatar
They do touch the frame at full lock. Not a big deal though. I hardly even notice it. The toyo's have alot of side lug on them though. If you went with something different they probably wouldn't touch. These toyo's are awesome though.
Old Jan 26, 2005 | 09:56 AM
freddytran's Avatar
bump for ya. i'd like to see some pix too.
Old Jan 26, 2005 | 04:23 PM
KaNigIt's Avatar
Maybe i got this completely wrong... but if you say that it only slightly rubs on the frame.... then since the front suspensions are the same (at least i thought they had to be since the lift kits work for both), it should still fit witht he same minor rubbing of the fram and maybe some extra rubbing on the fender on the 2wd?
Old Jan 26, 2005 | 05:54 PM
Beaver Tricks's Avatar
OK, I found them..... 2.75" leveling kit on a 2wd with BFG 315/70/17's. Now, on stock rims, these tires rubbed a little teeny bit on a hard left. When I put the Eagle Alloy 186 rims on, I didnt make it out of the lot without cutting and hammering.
NOTE: This is BEFORE, I got my 6" suspension. Which i obviously have with no problems on rubbing,.......
Pics are below. in case they dont come up, they are saved in my "misc" gallery.
Old Jan 26, 2005 | 05:58 PM
Old Jan 26, 2005 | 05:59 PM
Old Jan 26, 2005 | 06:01 PM
Old Jan 26, 2005 | 06:03 PM
Old Jan 26, 2005 | 06:06 PM
KaNigIt's Avatar
AWESOME! THANKS ALOT!!!! I know these tires are suggested for an 8 to 10 in wide rim.... but like you did, I plan on getting other rims later down the road. Did you have any problem on the stock rims and did the installer give you any grief about it putting them on?
