Front suspension diagram and torque specs
Old 09-28-2004, 05:18 PM
slalomdude's Avatar
Iam getting ready to install a Autospring 1 1/2" levelling kit. Does any one have a pic or labelled diagram of the suspension, including the torque specs for the bolts
Old 09-28-2004, 05:43 PM
trierguy's Avatar
If you have a fax number, I'll fax a few pages for you from the ford service manual.
Old 09-28-2004, 08:52 PM
TonnyG's Avatar
trierguy
If you don't mind I need this too, my fax number is 309-213-6387
TonnyG
Old 09-29-2004, 12:22 PM
slalomdude's Avatar
Can you fax to 863-619-2478.
Old 09-29-2004, 12:47 PM
trierguy's Avatar
Hey guys I will get these faxed to you later this afternoon, heading out the door for lunch now. Expect them arround 2:00 central time.
Old 09-29-2004, 09:14 PM
slalomdude's Avatar
You're the man , thanks for that info. I will be fitting the kit next weekend
Old 09-29-2004, 09:55 PM
CodeRed's Avatar
Hey for you guys who got the faxes today, could you tell me the torque specs for the following?
Bottom of sway bar link to lower control arm?
Upper knuckle to upper control arm ball joint?
Top of strut assembly to frame mounting bolts (3 of them)?
Thanks!! Brandon
Old 09-30-2004, 04:32 AM
bluestang67's Avatar
Great info i ordered the 2 1/2 Autospring i will make a block to pick up rear end if it's down a tad. 1/2" or 1" . Measurements should be within one 1/8 though.
Old 09-30-2004, 12:19 PM
jdmclemore's Avatar
1 more fax?
I don't suppose you could fax that one more time?
214-567-9793
Thanks!!
Old 09-30-2004, 12:22 PM
Ghengis's Avatar
TierGuy,
Hate to be a pain, but I could use them also
Fax# 609-259-5542
thanks
Dave
Old 09-30-2004, 03:09 PM
shane_wilson's Avatar
i want them too please!!!!!!!!!!
386-755-0771
Old 09-30-2004, 04:50 PM
jdmclemore's Avatar
Got the fax - THANK YOU!!!!
Old 04-09-2005, 08:36 AM
blacklariatfx4's Avatar
Is there anyway that someone can scan or just type out the torque specs for the following;
I would just ask trierguy for the fax but our cartridge is no-longer produced and I'm planning on doing the install later on today.
Thanks, Jerry
Old 04-09-2005, 11:24 AM
klassic's Avatar
Cut and paste. If there is a wrong value it is a Ford misprint.
Torque Specifications Description Nm lb-ft
Wheel nuts 204 150
Front Suspension
Wheel hub-to-wheel knuckle bolts 200 148
Tie-rod end nut 150 111
Front axle-to-wheel hub nut (4x4) 27 20
Upper ball joint nut 115 85
Upper arm-to-frame nuts 150 111
Lower ball joint nut 150 111
Lower arm-to-frame bolt and nut 300 222
Shock absorber upper mounting
plate-to-frame nuts (M10) 48 35
Shock absorber-to-lower arm
bolt and nut (M20) 475 351
Stabilizer bar bracket-to-frame bolts 48 35
Stabilizer bar-to-link nut 133 98
Stabilizer bar-to-link to
lower control arm nut 90 66
Anti-lock brake sensor bolt 18 13
Caliper anchor plate-to-wheel
Caliper-to-anchor plate bolts 32 24
Old 04-09-2005, 02:38 PM
klassic's Avatar
Hey RockPick.... I've posted these specs a few times now. It seems a lot of guys want them (and some other torques).
Maybe a torque value sticky is in order.
Then people who need numbers fast can pop on line and continue with their wrenching.
Just an idea...
Quick Reply: Front suspension diagram and torque specs
