Transmission Malfunction
Old Apr 20, 2004 | 06:41 AM
ImBroke's Avatar
Unhappy Transmission Malfunction
Leaving the house, the info center told me I had a "transmission malfunction". This was accompanied by the blinking OD light. I shut the truck off and restarted, and it went away. It's going to the dealer to at least get it documented that I had a problem. Reading other posts, if it craps out after 36k, and I have brought it in several times for this, maybe they'll cut me a deal on a new tranny?? That is of course, if there is anything seriously wrong with it.
Old Apr 20, 2004 | 07:28 AM
momalle1's Avatar
Getting things documented is always a good idea. Considering your truck is fairly new, if you don't have any problems between now and 40k, it may not buy you much, but it surely won't hurt.
Old Apr 20, 2004 | 09:03 AM
beastboy's Avatar
I had it happen twice....bot times I had less than 5K in miles.....the dealer said they couldn't find anything, but would call me if any service bulletins came through. I haven't had a problem in about 6 months.
I do notice that sometimes when i put it into drive from reverse, it takes a couple seconds in engage.....anyone else notice that?
Old Apr 20, 2004 | 09:32 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Originally posted by beastboy
I had it happen twice....both times I had less than 5K in miles.....the dealer said they couldn't find anything,...
I had an intermittent transmission problem with my Ford van that was very frustrating along with the blinking OD light.. It would never mis-behave at the dealer and there was no code.
The dealer plugged a 'flight recorder' into the computer. When the next malfunction occured, I pressed a button and the code was 'trapped'.
Turns out it was a $69 sensor on the transmission.
Old Apr 20, 2004 | 11:22 AM
wwblueScrew's Avatar
I have the 2 second delay when going from drive to reverse also. It's been that way from day one so I assumed it was a characteristic of the new transmission.
Old Apr 20, 2004 | 11:24 AM
beastboy's Avatar
I see it sporadically....so that is why my suspicions are woken.
