Fog light Question
Old Apr 14, 2004 | 12:11 PM
jamzwayne's Avatar
Fog light Question
Is there some way to run JUST my fog lights?
I can only turn them on if the headlights are turned on. I have to turn em on then pull to get the fogs on. If the heads are out I cant pull the switch to get JUST the fogs on.
Old Apr 14, 2004 | 12:19 PM
Dusty1's Avatar
You can turn them on in conjunction with just your parking lights, but it has to be either parking lights or driving lights.
Old Apr 14, 2004 | 12:24 PM
Dusty1's Avatar
I keep forgetting you have a Heritage. However, I'm guessing it's the same in this case. It would make zero sense in dense fog not to be able to turn off the driving lights (it would totally negate the reason for having fogs lights in the first place!), but you would want to keep the parking lights working with the Fogs.
Old Apr 14, 2004 | 01:00 PM
jamzwayne's Avatar
Thanks Dusty.
I was hoping someone knew of a way to "alter" the switch to have the fogs on alone.
Old Apr 14, 2004 | 01:12 PM
Dusty1's Avatar
Ok, I understand now. Can't help you there, unless you want to pull the fuse...
