Turn Signals don't Work!!
Ok, here's the story, about two weeks ago, my turn signal started not to function properly. It would like do the blinking thing for about 5 or 6 times and then just freeze. So today I decided to see if there was something worng with the fuse, I took it out, looked at it,(I looked at fuse #2 BTW) and nothing was worng with it, nothing at all, it still looked pretty new. So after looking at it to see if anything was worng, I put it back in the fuse box and and go to the driver's side to try the turn signals, and guess what happens. They don't even turn on:confused:. So this is the part where I come to you guys for help, and of course I'm also going to take it to the dealer to check it out, can you imagine driving this rig without any turn signals:eek:? Any help WILL BE greatly appreciated.:)
My truck did the same thing. Progressively got worse over a span of a couple of weeks. I thought it was a fuse so I took it into the dealer and my assumption was correct. Have had no problems since then.
I had a turn signal relay go out before, wasn't hard to change out in my old Ranger. I wonder where the turn signal relay is located in the F150?
Not that it really matters, since that's what the warranty's for. I worry about bad fuses, however. You gotta wonder what caused the fuse to blow. That's usually an indication of something more sinister. Let us know what the dealer finds! :( |
Yeah, then they totally violate your baby and rip out her insides to find the problem.
The first day I had my truck, the damn power seat/power pedal fuse blew. They wouldn't just replace the fuse. So they took her in, took out the seat...hang on...let me compose myself...pulled up the carpet...and found a pinched wire. That was a tough one to swallow. |
| All times are GMT -4. The time now is 08:37 AM. |
