Skid Plates
Re: Skid Plates
Originally posted by Wolfman064
Has anyone checked into the possibility of adding skid plates aftermarket?
I suppose if you want them because you actually want to off-road... then maybe aftermarket are the way to go. You would probably get thicker metal thats less likely to bend when you hit a rock.
If you are doing it for looks... whats the point. No one can see under there unless you have a big lift.
It sounds like you didn't get factory ones - where did you go? Price?
Originally posted by SteveV
Do the Ford skid plates get in the way for an oil change (i.e. drain plug and filter removal)?
