1998 4.6 liter V8 will not start when engine is hot
1998 Ford F150 4.6 liter - The symptom is described as not starting after the truck warms up; it will turn fine, it runs fine, no OBDll codes. It always starts fine when its cold or has been sitting for an hour. Any help would be appreciated starting with the cheap/easy things.
Try it with your foot on the floor. You may have leaky injectors and it's flooded.
If the injectors are leaky, they will dribble fuel into the cylinders till the fuel pressure is all bled off. Sitting for an hour lets the fuel drain past the rings into the crankcase. Pull your dipstick, if it smells like gas that confirms this.
