97 f150 4.2 temp guage pegs
Old 06-22-2018, 10:10 AM
Daniel07's Avatar
temp guage stays high with key on all the time other guages are ok. Is this temp guage still a simple analog circuit ? and maybe just a short to ground ? and does anyone have a wiring diagram for this ?
Old 06-22-2018, 10:24 AM
You can check the temp sensor by using a DMM in resistance. If it has a short/open, it will indicate it.
Old 06-22-2018, 02:39 PM
glc is offline
It is not a simple analog circuit. It's progressive till it gets up to normal operating temperature, then it stays in the middle till it overheats, then it will suddenly peg.
Old 10-10-2018, 11:12 AM
Anthony Edu's Avatar
I have a similar issue with my temp gauge. Does anyone know the location of the temp sensor so I can test it out? Thanks!
Old 10-10-2018, 11:59 AM
According to this diagram the Cylinder Head Temp sensor is located in the rear from the passenger side. Is this the temp sensor we are referring too? (C107)
Old 10-10-2018, 01:12 PM
glc is offline
Yes, the temp gauge uses the CHT sensor since about 1999.
Old 10-10-2018, 03:32 PM
Cool! I guess i should start there and see if the wires are okay before removing the gauge cluster for possible repair.
Quick Reply: 97 f150 4.2 temp guage pegs
