2003 f150 xlt
2003 f150 xlt
So i have no idea whats wrong but every now and then when i start my truck it sounds like my hazards are on but going much slower. The back light for my radio, milage, and back light for my speed/rpm/ect flashes it also causes my hazards to slowly flash if my lights are not on. And when i try to turn my truck off even when the key is pulled out and its in park it will continue to run for several mins before eventually dying. What is wrong with my truck?
Sounds like your GEM module got wet or it's failing. Common problem.
Replacing the GEM is a bit of a pain in the neck but not terribly bad.
If there is any possibility that the windshield leaks make sure you get that resealed first.
You don't want to kill a second GEM.
The GEM module is under the dash, drivers side. Fuse box is attached to it.
Look on YouTube, there are tons of videos on how to remove it and replace it.
on
The GEM cannot cause the symptom with the engine continuing to run. However, the fuse box under the dash, if water-logged, can cause it. Could easily be that both are damaged plus there may be a bad ground. Since it doesn't cost any money for parts to check the grounds, pull the kick panels on both sides and inspect them for corrosion or loose connections. Start on the driver's side.
