Almost got stuck
My 2002 Super Crew won't lock into 4 wheel drive. I kind of needed it. Could it be something as simple as a fuse?:help:
Originally Posted by Nickl242
(Post 5223645)
Could be just a fuse. check all fuses and relays might be that the vacuum line come off? does it run well? the shift solenoid might be bad or just sticky too. Or the electric motor on the side of the T-case. I see that you are from Florida....were you in area that got a lot of heavy rain? or drove threw high water? Any puddles on the inside of the cab floor on the drivers side? |
enriched, Yes it is electronic and we did have very heavy rains. I purchased the truck in February, it's in excellent condition minus the rear of the cab leaks. When engaging the switch there is no sound like you would normally hear when locking. I will check fuses, relays and the vacuum line. Any idea what the issue would be if there is no vacuum? Thanks for your response.
(Post 5223680)
if the vacuum is not working the working to the front axle then you need to check the vacuum solenoids on the fire wall Also make sure that the shift motor is working on the T case. |
Enriched, thank you for your help. I don't have any windshield issues and will check the vacuum and solenoids. I appreciate your insight.
