33's Yes or No?
I have 2000 f150xlt scab 4x4 with the 5.4 and I want to put 285/75/16 tires on my truck. I know that they will fit, the kicker for me is that my truck has 3.31 gears. I have read a lot of these forums and I still have not found anyone else that has 3.31 gears with a 5.4 but me, everyone has either 3.55 or 3.73. I dont plan on towing anything and wont haul anything heavier than my four wheeler in the bed (600 lbs or so). I do however like to go offroad, especially during hunting season, but I know my limits and will not push the truck up trails that seem iffy. I dont expect the truck to be a racecar and I dont do burnouts so I dont care if moving up to 33's will slow it down some. I just want to hear peoples opinions or experiences with this engine/gear combo with bigger tires. Or an suggestions you guys might have.
Thanks, Jim |
Here is a Pic of the truck as well. https://www.f150online.com/forums/me...0&ref=gnr-prev
You're probably gonna get a few different opinions on this, but I say no. It will be an impact. Will be undriveable?? Absolutely not. Will it damage anything?? Absolutely not. Will it be fun to drive?? Absoluely not. Will you notice the ding in performance and everyday driveabilty?? Absolutley. Gas mileage will suffer also, possibly significantly. I didn't like my 33's with 3.55's; can't even imagine how bad it'll be with 3.31's.
Fords modular motors (4.6, 5.4, 6.8) all make their power at higher rpms than the pushrod engines of old. 3.31 is too tall for these types of engines. 33's will only make the gearing taller. You can do it, they will fit, but you will be a long way from the power band of the truck. If you don't tow or haul much, maybe you won't care. If you like having access to the engine's power, you will care.
Originally Posted by bchauler
(Post 5069767)
Ever heard the saying there's no substitue for cubic inches? Well, I like to say there's no substitue for proper gears! No, a tuner is not a replacement as it doesn't change the rpm operating range of the engine; it would be a band-aid to the true problem. And for what a tuner with a good program costs, you're not far off from saving up the money to get gears! And it's not just all about towing, it's about the normal, everyday driveablility of the truck; the fun factor will be gone.
Originally Posted by 270shooter
(Post 5069781)
I'm not saying you're wrong or anything but I always thought it was the opposite of that. That the 5.4 made peak torque at 2500 Rpms. |
(Post 5069817)
And from what I know the 6.8 is very low torque not rev happy at all.
(Post 5069874)
Having owned a 6.8, I can tell you that the v10 power band is a lot higher than what most people are used to. Do some reading in a v10 forum, and you'll find that these engines make a lot of power, but you have to be willing to let it scream.
Originally Posted by Galaxy
(Post 5069813)
Make no mistake, the v10 does pull great down low, it just makes maximum power at higher revs than many are used to. Compared to a 5.4, the 6.8 has a lot more grunt.
If you are towing heavy up hill, most people find that they have to wind that modular up, a very different experience from diesels or ohv v8's. |
270,
I too had the 3.31:1 gears in my 2002 extended cab 4x4 4.6 when I purchased it back years ago. The truck came with the stock 235/70-16 tires, and that combo made me re-gear my truck, for my towing purposes. I re-geared to 4.10:1, an currently have two sets of tires I swap between. I run either 265/70-16 or 285/75-17 tires. with the 285/75-17 tires, the truck pulls and acts just a bit better than the setup (235/70-16). with the 265/70-16 combo, it feels like it is right on the money with acceleration, gas mileage and all around drivability. the 265 size combo yields me between 13.3-14.2 mpg city, up to 16-17 mpg highway. with the 285 tire size combo, yields me a bit lower mileage-13.1-13-5 mpg city and up to 16 mpg highway. The 4.10:1 gears work great for me, as I spend time up in the mountains on fire roads and such, and either tire size also works. :coffee: Hmm, anyone around or near you have a set of the same size tires that you want to try out mounted on 5x135-16" wheels? just to see if it would work out for you? or some used tires on craigslist. |
Originally Posted by 2002 wonderboy
(Post 5070237)
270,
| All times are GMT -4. The time now is 12:32 PM. |
