Gear swap in front axle
Old Jul 21, 2013 | 07:05 PM
cotedog03's Avatar
A few years ago I bought a 9.75 that had already had 4.56 gears installed to replace my 8.8. Now I'm finally looking at replacing the gears in the front axle. From what I've read it seems like a pretty challenging job, so I figured I would take the front pumpkin out and let someone knowledgeable do the job. Obviously I need to buy the gears, but as far as install kits go what else should I need? I've seen Yukon's install kits priced anywhere from $40 to $200 and not sure of what to get.
Old Jul 21, 2013 | 11:06 PM
str8t six's Avatar
get a master install kit. it comes with bearings and shims.
the front axle is pretty easy to get out. you barely have to jack up the front end to get it out.
Old Jul 22, 2013 | 01:42 AM
jgger's Avatar
Make sure to get the proper gears. They need to be reverse cut for the front.
Old Jul 22, 2013 | 02:27 PM
cotedog03's Avatar
To get the front pumpkin off will It just be unbolt and done, or do I need to pull each axle side out a little like you would on the rear?
Old Jul 22, 2013 | 02:52 PM
str8t six's Avatar
yup, just unbolt it and its out. unbolt the cv axles, drive shaft, and the mounting bolts. dont forget the vacuum lines, etc..
Old Jul 22, 2013 | 02:55 PM
str8t six's Avatar
should look like this when its out. but not upside down lol
Old Jul 22, 2013 | 05:42 PM
cotedog03's Avatar
damn that's a clean one. thanks!
Old Jul 22, 2013 | 06:25 PM
str8t six's Avatar
yeah that wasnt mine
Old Jul 22, 2013 | 09:13 PM
cotedog03's Avatar
will the master install kits for the standard 8.8 and the reverse cut 8.8 be the same?
Old Jul 22, 2013 | 10:15 PM
str8t six's Avatar
im not sure. i wouldnt risk it tho
Old Jul 23, 2013 | 12:06 AM
jgger's Avatar
It should be, the ring and pinion are cut different for the front and back because they turn opposite directions. The master install should be bearings, shims, and crush sleeve. Pretty sure they are the same front and back.
Old Jul 23, 2013 | 08:48 AM
cotedog03's Avatar
That's what I thought, because the "front axle" master kits look identical and are twice the price. But I'd think all parts would be the same size or it would defeat the purpose of calling both an 8.8. But that's just my simple logic
Old Jul 23, 2013 | 09:58 AM
str8t six's Avatar
here ya go. i would give them a call to make sure this is the exact one you need tho.
i cant remember which one i used for mine.
http://www.diffsonly.com/yk-f8-8-rev...-differential/
