F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   1997 - 2003 F-150 (https://www.f150online.com/forums/1997-2003-f-150-118/)
-   -   what's the difference between the 4.6l in the f150 and the 4.6l in the Mustang? (https://www.f150online.com/forums/1997-2003-f-150/481740-whats-difference-between-4-6l-f150-4-6l-mustang.html)
wildmike1941 Jan 3, 2013 10:08 PM
I've been trying to find info to figure this out. I found parts for the 4.6 Mustang like the SVE Cop's and, other components and I'm wondering if they're interchangeable.
chrmar Jan 3, 2013 11:14 PM
Block is interchangeable. Intake manifold, valve covers, oil pan, front drive pulleys are all different.
wildmike1941 Jan 4, 2013 02:49 AM
Chrmar- so the cop's, probably won't fit? What about the injectors? I found some in a mustangs and fast fords mag. I currently have Accel cop's and e3 plugs, stock injectors with stock fuel rail, but I've has a bad misfire for a while. I understand stock would probably work best to smooth out the misfire, but I'm really trying to pull some more HP out of this motor. The truck is currently being built to be a desert race truck/weekend you,
Toy, not you. Lol
Fordtrucktexan Jan 4, 2013 06:38 AM
I know the cams are different but not sure about anything else. The truck motor shares more in common with the crown vic than the mustang
JCR 56 Jan 4, 2013 08:47 AM
On the cop ignition system, motorcraft is probably the best out there. Accel cops are probably the worst,from what I can gather. As far as plugs go, some recommend NGK,
and Denso iridiums, I use motorcraft. On these modern ignition systems, sometimes using anything but oem, is less performance instead of more.
Toyz Jan 4, 2013 09:10 AM
I already mentioned for your NA system, OEM cop's are superior. Do not waste your money on anything else telling you otherwise.
Visteon coils can be found on Ebay and are oem specific (relabeled motorcraft) Search visteon coils DG508
If you want to upgrade your plugs.. denso iridium's would be recommended.
dewalt17 Jan 4, 2013 10:04 AM
Some Mustang Underdrive pulley systems will fit an F150. Steeda confirmed this for me awhile back.
chrmar Jan 4, 2013 05:12 PM
The difference to look out for is the width of the pulleys; some F-150s have 8 belt ribs on the pulleys while Crown Vics and Mustangs have 6 ribs.
dewalt17 Jan 4, 2013 05:42 PM
They are 8 rib all the way up to at least '03, iirc. My '05 is 6-rib. :think:
4.6heavymods98 Jan 4, 2013 06:00 PM
Dont think your 4.6 F150 is going to be fast if you put swap mustang parts into it. The only thing that would make a difference is a supercharger or turbo. I have close to 350 HP on my 4.6 and its still not what I consider quick. Remember these are heavy beasts!
stoffer Jan 4, 2013 06:06 PM
my wife's old '03 was a 6 rib, 101 inch belt..
stoffer Jan 4, 2013 06:09 PM
since when??? :lol:
the two valve PI motors had the same cam stock in both 4.6 and 5.4 applications regardless of what vehicle they were in
stoffer Jan 4, 2013 06:10 PM
so get rid of those E3 pieces of crap, install some decent plugs and swap out your COPS
wildmike1941 Jan 4, 2013 11:32 PM
Ordered the visteon Cop's today, and I've had some motorcraft plugs in the garage from my old f150, I guess I can always get a ranger to play in later... I just really wanted to pull HP out of this motor, I was looking for 500+, but I think I'm just gonna buy a ranger later on. Thanks a lot guys!
