Truck won't idle
Old Oct 1, 2011 | 09:51 AM
wrenchturner's Avatar
Truck won't idle
I have a 2001 F 150 surercrew 5.4L that on random startup don't won't to idle (arround 400 rpm). It doesn't do it all the time, just at random. I have replaced the fuel pump, fuel filter but that didn't fix the problem.If iI give it a little gas when its idling low it will eventuallly pick up the correct idle (arround 750). I have cleaned all the componants above the intake manifold, but no fix yet. I read on this forum that some models have a fuel control module, I looked and didn't find one on mine. Can anyone help? Thanks in advance!
Old Oct 1, 2011 | 09:58 AM
No fuel control module (FPDM) on a 01, it's a full return system with a pressure regulator on the rail. You can borrow/rent a fuel pressure gauge to check that. Why did you replace the fuel pump before checking that?
Clean or replace the IAC (idle air control).
Old Oct 1, 2011 | 10:43 AM
I checked the pressure and it was 34 psi and the tech said it should be above 40 to work proper. Is the IAC a electronic piece?
Old Oct 1, 2011 | 11:04 AM
It should idle fine at 28 or higher. The pressure should go up when you remove the vacuum hose from the regulator.
The IAC is electro-mechanical.
Old Oct 1, 2011 | 11:13 AM
jbrew's Avatar
Above 40 ? That's incorrect. Like glc said, 28 psi is a good pump. 34 psi is average. Above 40 would be without regulator.
Old Oct 1, 2011 | 11:15 AM
Thanks for the info glc. I'll check it out!
Old Oct 1, 2011 | 11:17 AM
Thanks jbrew for the backup!
Old Oct 1, 2011 | 11:22 AM
jbrew's Avatar
No problem. He's right about the IAC as well. You can either clean it up inside w/DeepCreep while working the mechanicals w/compressed air to assist. OR, just purchase a new one.
That's why it won't idle.
Old Oct 6, 2011 | 11:19 AM
Thank you glc and jbrew!!! Replaced the IAC and truck idles fine! Hope I can be of service to you both some day!
Old Oct 6, 2011 | 02:54 PM
sniknah's Avatar
Jbrew rocks! He's helped me several times, he is a HUGE asset to this board.
Old Oct 6, 2011 | 04:04 PM
PirateSignal's Avatar
Yeah, these guys (and many others) are a huge asset to this board. Invariably the answers you need are here. Great site, great posters.
Old Oct 7, 2011 | 01:44 AM
jbrew's Avatar
This might be the proper time to put in for a raise. (?)
Old Oct 19, 2011 | 08:10 AM
hopperwagonbob's Avatar
Great info! I'm having the same random idle problem. Where is that part located? Other wise truck runs fine.
