Sas
#31
I personally wouldnt use a D44 of any form. If i was sticking to 38's then a D44 HD (8-lug) would be an option but would probably still go to a D60. The chevy axle with have the diff on the passanger side. Its not that big of a problem but it would be easier to use a Ford D44 or Ford D60
#32
Mount it were ever you want. just make you up a little crossmember and bolt it to both fram rails. what divorced case is it?
If its free, go for it... I wouldn't buy it though.
If your trying to do it on the cheap fab your own front end up. it's pretty simple if you know how to cut and weld.
I would get shocks too. You may incounter a terrible death wobble for not setting it up correct.
#34
#39
