Just thought I'd share my project.
Old Jul 27, 2010 | 09:35 AM
Dan Haze's Avatar
I'd just thought I'd share my new little summer project that I'm pretty stoked about. This past weekend I picked up this rolled over 2002 supercrew that I'm going to use as a donor with 80,000 on truck and motor, freshly rebuilt trans, shift kit, stall, poi rear w/410 gears, programmer, fms fuel pump and injectors, and a few other goodies. Got a really good deal on it, so I've decided to do a entire swap with my 2001 silver flareside which now has about 180,xxx on a still tired running 4.6. So far I've just been breaking down the donor to get rid of a bunch of stuff I don't need to clear room, because I finally convinced my parents to let me do this at there San Antonio house by promising them that the garage wouldn't look out of hand . Although I'm not new to doing my own mechanical and maintenance work, this is my first time doing this type of project, I know that everything should be pretty straight forward when swapping and should be a direct fit on my truck (if wrong please correct). But, any input, advice, or tips would really be appreciated.
-Dan
Donor
After first day, with some help.
Just a few random pictures.
On the left is my old DS, Supercrew is just a tad shorter.
Just a difference in both rearends. Top is the 9"
My truck goes under the knife.
Motor out.
Man, the place was a mess for a little bit.
My 2001 Flare
Old Jul 27, 2010 | 09:51 AM
48prerunner's Avatar
Are you just going to swap cab and bed or are you putting the drivetrain out of the rolled truck into your flareside?
Old Jul 27, 2010 | 10:57 AM
thejake1989's Avatar
ill be watching haha
Old Jul 27, 2010 | 01:00 PM
Dan Haze's Avatar
The plan is to pull the complete engine/trans, & rearend out of the rolled crew and just swapping into the flareside. Everything was running fine even with the truck rolled like it is, so I'm guessing I shouldn't have to many issues.... Right??
-Dan
Old Jul 27, 2010 | 01:13 PM
b2therad's Avatar
You should sell me some interior parts :P.
You shouldn't have any issues unless you are switching to a 5.4. At that point you will need to make sure that you have a driveshaft for a 5.4(9:75) there, and you will need to get your 4.6 PCM reflashed to accompany the 5.4. Other than that, have fun!
Old Jul 27, 2010 | 01:20 PM
blackedoutV6's Avatar
i love your flare!
this should be a sick build.
brads right about the dshaft. Id just have one custom made honestly, it should run you around $250.
I think swapping all the electronics from the donor truck might be a good idea...
Old Jul 27, 2010 | 01:33 PM
dirtyd88's Avatar
if you do get a custom DS, make sure to go with a 2-pc.
Old Jul 27, 2010 | 01:39 PM
1clean42's Avatar
Why should he have to change driveshafts? The transmission should be the same and shouldn't make the distance from the tranny to the rear end any different.
Old Jul 27, 2010 | 01:40 PM
b2therad's Avatar
9:75s have a much larger housing and therefore need a shorter driveshaft.
Old Jul 27, 2010 | 01:42 PM
1clean42's Avatar
Not all 5.4s come with 9.75s.
Old Jul 27, 2010 | 01:44 PM
b2therad's Avatar
Well I do apologize.. I dont see a supercrew 5.4 coming with a 8.8, but whadda I know?
Old Jul 27, 2010 | 01:48 PM
1clean42's Avatar
No need to apologize, lol...just did some searching and I guess I'm wrong. Coulda sworn they only came on 7700s and Lightnings.
Old Jul 27, 2010 | 02:05 PM
THIS! Your lowness will appreciate it.
Old Jul 27, 2010 | 02:49 PM
Dan Haze's Avatar
I figured i would have to have a new ds made to fit since the crew is obviously longer, different ends and won't fit the flare. I am going to consider a 2 piece since i do plan on going lower in the future. besides tune/recalibration,custom-made ds, i should be in the clear according to what I've heard. again thanks for the responses.
Old Jul 27, 2010 | 03:15 PM
dirtyd88's Avatar
actually, IIRC, Patrick told me that the supercrew and supercab are the same frame....i want to say the same wheelbase as well, but don't hold me to that one...:o
