Clyinder 8 Misfire? I've tried everything I know
This problem I'm describing in on a 98 F150 4.6
I was getting a Cylinder 8 code so I changed plugs and wires. Then on a trip to Missouri from Wyoming I got a Lean Bank 2 code and another Clyinder 8 misfire code. So I've fixed my exhuast leaks and replaced the fuel injector for that clylinder. And the misfire code is still on??? The spark plug was cracked when I checked it the second time put so far the new one is fine. I'm lost on this one. Usually I can trouble shoot anything on my truck, but I'm lost. I haven't switched the coils yet to see if the misfire moves. And I need to check the timing. I've heard this could be a compter problem with a short somewhere. Is this true. What else can I check? Any ideas that would help me out. Thanks |
I'd try changing the coils and disconnecting the battery for a bit to reset it. Then hook it up and see what happens.
My mom's 99 5.4 had that problem. After chasing it for a while, her mechanic found it to be a coolant leak was shorting out the coil pack.
Open up your hood in a dark garage/on a dark night, and see if you notice any plug wires arcing.
I had this same problem and after changing just about everything I put on a set of 9mm Ford racing wire which solved my problem. |
Yep, like the old 460 engines etc where you'd have to keep the wires that fire one after another away from each other, like 7/8.
Make sure the wires aren't close to the AC accumulator. There are posts on here describing this problem that I think apply to your truck and how to remedy. I would definitely look at replacing the coils.
get a v6
well since you havent checked fire id say that first but ive also seen injector wires break where the wires go into the loom and right at the connector.
K we checked everything the plugs wires and coils all passed. So we did a compression test and cylinder 8 failed miserably. So know we are going to have to go internal. thanks for the help
Probably a cracked valve as the spark plug was found damaged in orginal troubleshooting. The truck has 1992-1998 standard heads. Can I replace those with the 1999-up Performance Improved (PI) Heads, without changing pistions? |
Originally Posted by ahooten
(Post 4019192)
| All times are GMT -4. The time now is 08:56 PM. |
