I've got some holes in my yard that I wouldn't mind going and getting some top soil/fill dirt for. I figured that volume wise the bed can hold right at 2 cubic yards. Has anyone hauled 2 Cu Yds of dirt/TS before?
I did do some preliminary research on the web and found out that a Cu Yd of the above mentioned weighs anywhere from 1600 to 2400 lbs. Does anyone know if these numbers are accurate? I mean I would hate to see what happened if 2.4 tons of stuff were dumped into my bed.
And yes, the solution of only getting 1 Cu. Yd at a time has come to mind.
I'm sure it could do it but it would lower your bed a bit now if you get some load handler added to the leave springs that will help out on that or you could just do the 2 trips your thinking about.
I used to have a 00 f150 4x4 short bed x-cab and I had them dump 2 bucket loads of topsoil right in the bed. My bump stops on my bed were smashed into the axle. It pulled it just fine. I only wentabout 20mph as it would start to buck and jump. It can be done you just have to drive really slow so as to not break things.
Even with the Hellwigs, you 'should' not over load the trucks GAWR, which will be in the neighborhood of #3500. I've got the LP-25's as well, and while they are great for keeping the truck pretty level with #1000 payload, they are still attached to the stock leaf springs.
I'd only haul 1 yard at a time. Better to make two trips to the yard, then one trip with two yds and the other to the shop to fix whatever broke!
I've got a small utility trailer with a payload cap of #1500. I'll usually put a yd in the bed and a yard in the trailer. Wow, instant F250 payload!
That's what I need to do, find a trailer (two axle maybe) that I can haul stuff like that in.
I have looked a little bit at this Featherlite dump trailer, 10 ft. Man it's nice -- but pricey...
When the time comes I'll probably only end up getting a yard at a time.. Maybe I can convince my girlfriends dad (has a '97 F-150 4x4) to go with me -- that would only be a yard each then..
A yard of dirt weighs approximately 2,000#. A "bobcat" scoop is generally 1/2 yard. Mulch weighs about 1/3 the weight of dirt. No, I wouldnt haul 2 yards in the back of your truck.
My gallery: http://www.f150online.com/galleries/....cfm?gnum=1778
1989 F-150 4x4 351w 5spd
Mods so far:
4.9L to 351w swap
Temp, oil pressure, voltmeter gages
Electric fan
On my list:
Chrome nerf bars
Headers
Improved exahst
1994 Honda Magna
750 cc DOHC v-4
85 HP
12's in the 1/4
One nasty rice burner
I just cant see myself putting dirt,rock,gravel,etc in my "baby".Yeah its a truck,but shes made for hauling people in the cab.Oh,i have hitch balls on the bumper,just in case.Its a 97,LWB,work group,class 3 towing package.But,seeing that i am paying the monthly notes on it i can do as i please with it!!!!!!
__________________ 2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
