2000 F150 4.2L 5-speed, 197K, strong truck
i bought it new.
it was my daily driver for 11 years and then became a work truck also in 2011.
as my daily driver it also pulled a 3600 lb boat 20 times a year...
now it pulls a 3000 lb trailer 5 days a week.
just a few months ago it became a full time work truck when i purchased another truck.
in 197K miles i have replaced an alternator, a rotor and A/C system. the heater is starting to act up a bit, but i think a flush will fix it.
anyway, i am quite proud of this little 6 cyl. its a tough truck and i hope i get another 100K out of it
hmm, first it was not recommended because of my tranny and clutch.
now its the bumper height and angle.
look man, i got some towing package apparently. there are hooks under the hitch that are built in for safety chains.
the dealer stood there and personally told me it would pull my 3600 lb boat all day long. and it did !!!!
now it pulls 3000 lbs daily.
no issues
no issues
Just my two cents, not that it matters as your truck seems to be doing fine.
I know it seems confusing even though it states on the bumper that you have a 500lb tongue weight and 5000lb towing capacity, but it is the m5od that is the limiting factor.
My bumper says the same thing, but also says under that to check the owners manual as the numbers may be different for the specific truck. I have a frame mounted hitch, but don't really tow often or anything over 2000lbs.
Not trying to tell you to change anything, just trying to help possibly clear things up.
what is m5od?
