Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Wheels & Tires
Thread Tools Display Modes
Old 10-14-2008, 12:20 AM
Vehicle: 2005 ford f150
nitrogen vs air
i have found what i thought was a ploy to be true, nitrogen gets 1 mpg better than air on my truck. yeah i know its only 1 mpg, but hey at 3.29 a gallon every bit counts right?
Old 10-14-2008, 12:26 AM
Vehicle: 2007 Ford F150
Yep every bit counts.
Prolly notice the difference because the nitro filled tires will stay "filled" longer then air because of the bigger molecules. If you were the kind of person to always check your air filled tires and ALWAYS kept them properly aired you would probably not see any difference.
Aaron
Custom Tuned by Bill at Power Hungry Performance!
Old 10-14-2008, 12:38 AM
Vehicle: 2006 Ford F150
if i fill my tires with helium my truck can fly and i get 100mpg.
Old 10-14-2008, 12:40 AM
Vehicle: 2004 Ford F-150
Quote:
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Gloss Black Grills/valance/wiper cowl, 20% Tint, LED Reverse & Plate Lights
Performance: 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks.
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone
Old 10-14-2008, 12:50 AM
Vehicle: 2003 F-150
try using hydrogen, its the best!!!
(kidding)
I have nitrogen in my tires, didnt notice any significant gain or loss
Jmod
... 3/5 Drop... Tint 15%F 1%R... Dynomax Bullet Dual 16" Efans
P&P TB/Plenum... L HL/Corners... Painted Grill Custom Sub Box Reverse Fogs
jamzwayne : I'm not saying dont get any hoopie patch for your dang-dang
scott1981 : Fly your American flag, but dont let it block the view of your toyota.
gators241987 : Chris Hansen is a coc.blocker
Old 10-14-2008, 01:03 AM
Vehicle: 2008 Ford F150
nitrogen wont give you better gas mileage.. more psi will give you better gas mileage.. your "1mpg" increase was more than likely a psuedoincrease associated with simply putting more pressure in the tires.. mind you, there is very little difference in the composition of "air" in comparison to nitrogen.. air is naturally about 80% nitrogen to begin with.. so how can you assume that a 20% assumed variance will increase your mpg that substantially?
anywho.. consider this.. the atoms of nitrogen are larger than oxygen and etc, and oxygen and other elements only amounts to less than 20% of the air around us.. so say you regularly inflate your tire to about 30psi (24psi nitrogen/ 6psi oxygen/etc) and you had a drop in about 5psi/yr.. due to the molecular size of nitrogen, your losing about 4psi oxygen/etc and only about 1psi of nitrogen.. this brings you to (23psi nitrogen / 2psi oxygen/etc).. so you refill with regular air up to 30 psi, and now your at 27psi nitorgen/ 3psi oxygen/etc.. this could go onand on.. but in theory, after time (about 1-2years) you would naturally be running your tires on fairly pure nitrogen anyways from using air at the pump alone..
fact of the matter is.. nitrogen alone just wont increase your mpgs.. atleast not to any extent on passenger vehicles..
2008 Blackout FX4 - 6" Procomp, 35" Toyo MT, 20" Procomp 7005 wheels, 4.56 Yukon gears, True-dual Magnaflow exhaust, AF1 3.0" intake, VMPtuning X3, and a lot of black spray paint.
-Exhaust clip- http://s340.photobucket.com/albums/o...nt=exhaust.flv
Old 10-14-2008, 01:17 AM
Vehicle: 2008 ford f-150
but nitrogen fluctuates less than compressed air to temp changes.
Old 10-14-2008, 01:23 AM
meh..
nitrogen does a lot of things.. but like i said.. it already about 80% of the air you put in your tire.. over a couple of inflations, the air in your tire would nearly be pure nitrogen anyways, due to the permeability of oxygen over nitrogen..
Old 10-14-2008, 07:26 PM
I didnt realize Daniel Rutherford was still alive!
Old 10-14-2008, 08:25 PM
a friend of mine who works at a tire store once told me nitrogen really doesn't do anything signifigant and probably isn't worth the money invested in it. I also once saw a magazine article about a study done that showed tires dont run any cooler, dont maintain pressure longer and they didn't see any signifigant increase in mpg. i personally think its sales gimic, but thats just my 2 cents.
4" Rancho Lift 4.56 Gears
325/65/18 Terra Grappler M/T Mod Classic II
SI/DO Flowmaster Super 44
Old 10-14-2008, 08:53 PM
Vehicle: 2002 Ford F-150 5.4L
The hassle alone of getting pure nitrogen would negate any real or percieved benefits IMO.
'02 F150 XLT 4X4 SCrew. 5.4L
K&N FIPK
Flowmaster 40 si/do Exhaust
325/70 16 Nitto Terra Grapplers
16X10 MB Motorsport wheels
4.10 Gears
Rancho 4" lift
Edelbrock Extreme Travel Shocks
Autometer Carbon Fiber Oil/Trans Temp Gauges
Carbon Fiber Interior (www.dash-kit.com)
Peterson Fluid Sys. Remote Oil Filter
Mag-Hytec Diff cover
FTVB
Troyer Performance Electric Fans
Underdrive Pulleys
Amsoil Fluids Throughout
My SCrew'd Garage
Old 10-14-2008, 09:21 PM
the 18 x 9 rims i switched to now filled with air must have been the 1 mpg loss vs my stock rims and nitro fill. forgot they are wider. i know how to do simple math and i was getting 1 mpg less, forgot to factor the wider rims. i dont know what i would do without all the chemist on this forum.
Old 10-14-2008, 09:25 PM
Vehicle: 1995 ford f150
you should try filling your tires w/ methane i hear its the s**t
95 f150 ext. cab
5.0 v8
SI/SO flowmaster super 40
2 12" kicker cvr's
1 800 watt rms monoblock amp(blown)
new amp- hifonics bxi1206d
6.5" infinity reference up front
6x8" pioneer 3 ways back
saving for a new truck
Old 10-14-2008, 10:17 PM
Vehicle: 2008 ford F150
ok if it does not good in tires then tell me why so many racers us it ?
Old 10-14-2008, 11:37 PM
Again I think the benefits are based on the fact that the tires hold their psi longer because of the bigger molecules.
Aaron
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
