305's on a 4x2 with 3" Body Lift?
Yeah the 305's will fit they are the same height as the 285/75/16 I'm currently running. But I'm a 4x4. With a 3 inch body you should be fine.
Let me say this unless you are going to install the body lift yourself I'd go with a 4" or 6" suspension lift from Fabtech. They make very good kits for the 2wd's and you could go with a bigger tire. Just know you will need to go lower on your rear end gear. But that's a small price to pay for the "look"
Hope this helps.
Hope this helps.
