tire cupping on stock Goodyears
I have the same problem with a set of new Goodyear AT/S tires I put in my truck last summer. I rotated fron to rear and now the front tires are cupping again. I have been told by a mechanic friend that the tires were probably out of balance when they were mounted originally and I should have the tires warrantied out and replaced. He also mentioned that on 4x4 trucks there are shims that can be used on the front to correct the problem. I'll be having Kaufman tire replace the tires and fix whatever the cause as they are the ones that replaced the shocks and brakes in addition to selling and mounting/balancing the tires from the beginning.
