Mud terrain tire setup
What yall think is good set up for bfg mud terrain tires? (lift, wheels and that stuff) what other tire companies have better then the mud terrain?? i dont wnat to go huge i just want some bigger tires......little bigger then the all terrain ones on my expedition.......open to any suggestion and ideas.......thanks
Tires aren't a problem
Don't worry about lifting your truck to fit the tires. I am driving a 01' 4x4 SuperCrew with 305/70's on 16 inch wheels. The tires are Buckshot Maxxis Mudders. There is absolutely no clearance problems - no rubbing or bottoming out and it handles great. As a matter of fact, I loaded up 40 bags of horse feed in it this weekend (1 ton) and didn't rub. It was a little much for the suspension, but if that didn't put tire against fender, then nothing will. I also pull an 18ft horse trailer with 5 horses very regularly - no problems.
Bonus, the truck looks great with this size tire and the Buckshot tires outperform any tire out there. Look into them if you want a tire that you can use.
Good luck!
Good luck!
when it comes to tires dont just wing it. Go to a Off Road shop, not your local NTB, and talk to them about what your thinking of doing. I would get a 6" lift tho, Rancho has a good one, with 35" BFG's, or Pro Comp Mud Terains. Just be ready to replace them in 35k miles if you are lucky. Absolutely do not crank up your torsion bars, that is terrible for your suspension and will make your car ride like a brick. If you are that strapped get a body lift.
