ABS Control Module?
ABS Control Module?
F150 1997 XLT: I assume that the ABS Module is the part that is on the Master Brake Cylinder that has an actual wire connector to it. It's leaking brake fluid.. not a lot but enough.. and I've been trying to get a replacement part. It looks like it can be unscrewed off of the Brake Cylinder. It used to leak a little, but now it just got worse.. and my ABS light keeps flashing until I clean the plug out a bit. I've got to 3 auto parts stores and they don't carry it. What should I do?
Any help would be appreciated! Thanks.
