Getting a 275/75/R17 and speedo gear change
I'm about to replace my Goodyears this weekend...or next and i want to get the BFGs in a 275/75/R17. Right now i have 265/70/R17s. If i end up getting a taller tire, how do i change out the speedo gear? Is it a part i can just pick up at the dealer or will they have to order it?
Since you have a 98, you 'should' be able to swap out the VSS gear. Thing to do is find out how many teeth the stock one has. then drop one tooth for the size tire you are getting. That's just a guess, but it'll be closer then it is now.
I had to drop one tooth on my gear when I went from a 235/70/16 to a 265/75/16. That was about 2" taller then stock. I had a 20 tooth gear, so I put in a 19 tooth gear and it worked out just right.
