wheels for 7 bolt 250 light duty
I have a 98 f250 light duty with a 7 bolt pattern. i've looked around at a few websites for wheels but have not found any that fit a 7 bolt patern. do any of you know of companies that make a wheel that would fit my truck? thanks
I also have a 98 F250 LD, the LD's do in fact have 7 lug wheels. There are a few aftermarket wheels available but most of them aren't really that much better looking TO ME to warrant their cost. I don't know if the newer F150 7700's have 7 lugs or not. If they do you might start seeing more and more wheel companies making wheels for us. I believe the lug pattern is 7 x 150 on these wheels, if you look around (google) you can finds some choices.
Good Luck....
Qrazy
Good Luck....
Qrazy
American Racing has a few styles. www.americanracing.com
Weld also makes them, but they're special order. The 2K+ F150 with the (7700 pkg) also has the 7 luggers. The bolt pattern is 7x150mm.
