33's and brakes dont feel right now
You really went up a few sizes, and you have the same result that everyone has....the bigger tires act like flywheels and keep the truck going....
You will also notice at least a slight decrease in gas mileage and performance, since you changed the final drive ratio of the truck...
It happens to all of us, but it sure looks great, doesn't it???
There are brake upgrades available, but most of us just live with it and enjoy the new look and ride!!!!!!!!
Thats normal, just basic physics. What you changed was the diameter of the tire, the weight change is very, very small. Basically you are trying to stop the truck within the same distance, ... but you have fewer tire rotations to do it in. Your brakes and rotors have to work a bit harder. It's give and take, your truck looks cool now, but has less power, and is harder to stop now.
Try this to help your brakes:
Pull the calipers off the rotors as if you were going to change your pads. Loosen the bleeder screw on the caliper and press in the piston with a c-clamp. Don't forget to attach a line on the bleeder to feed the fluid into a cup and not spray it everywhere. Tighten the bleeder and reinstall the caliper. Top off your fluid in your brake reservoir and try that. This worked wonders on my ride. I have 35s and it stops just as good as it did with the stockers.
This method rids the brake system of the burnt fluid right next to the brake piston. THis is were the fluid gets the worst in the brake system!
Before I installed the 35s I noticed a bit of spongyness in the brake system but it wasn't too bad. I installed the large tires on and it WAS bad! I did what I said above and now it's great
kev
kev
