33's on stock 17 inch wheels
Old 02-19-2002, 08:13 AM
Rudy in Mannhei's Avatar
Thumbs up 33's on stock 17 inch wheels
I have a 2000 flare side F-150 4X4 with 265x75x17 Goodyear AT's. Does anyone know if I can go to 33x12.50x17 tires without a lift?
Old 02-19-2002, 12:36 PM
wandell's Avatar
Yes, go for it!
Old 02-21-2002, 04:31 AM
33 tires
Do you have actual experience with this swap? I don't want to run into tire rub or anything
Old 02-21-2002, 09:23 AM
wandell's Avatar
I am running 285/75s (33x11.50) on aftermarket 16x10 inch rims and I only had to do some minor trimming of the lower, plastic valance on the front bumper. I know that several members of this site and F150 World are running 305/70s (33x12.50) on their stock 17x7.5 inch rims. You may have to trim your bumper valance but I doubt it with stock rims.
Old 02-21-2002, 09:31 AM
33 tires on 17in rims
Thanks for the help. There seems to be enough clearance there, but since I live in Mannheim Germany, it would be hard to get the lift kit here and then explain to a German how to put it in. Also, he wouldn't have SAE tools, only metric. Just a quick question. I'm new to this forum having just bought the truck. How do you include the description of your truck like it is included in your message? Rudy
Old 02-21-2002, 01:29 PM
mjs's Avatar
mjs
mjs is offline
Yes, 33x12.50s on the stock 17" rims fit just fine. No rubbing, no trimming. Yes, I have the 33x12.50 Procomp ATs on my Supercrew.
MJS
Old 02-21-2002, 02:30 PM
TJ2000's Avatar
Anyone have pictures &/or suggestions for 33's on F150 4X4 Off Road without any Lift ?
Debating about using existing stock 17's or buying 16's.
Old 02-21-2002, 02:32 PM
Jimmy Lee's Avatar
Yes!
JJ
Old 02-21-2002, 02:36 PM
PBALL's Avatar
Post
Rudy, you ask about adding your truck description to your signature.
1. go to 'user cp' on top of the forum's page
2. then go to 'edit profile'
3. next scroll down to 'Signature' option: Type in your truck description and after your done, the next time you post in a forums thread and before you click submit post, click "show signature" option above the submit box. There you have it, that should do. Hope this helps.
PBALL
Old 02-22-2002, 03:42 PM
mthunwardsen's Avatar
You should be fine on the stock wheels. I don't have any lift other than the little bit extra body lift on the Off-Road 4x4 package, you shouldn't need to lift your truck. I just got some ProComp 33/12.5R17's mud terrains put on some American Racing 17"x10" rims on mine. I had a little bit of rubbing on the front fenders. It was on the lower portion of the vailance fender, but it is plastic anyways. I just shaved the plastic off (about 1/2"), but you can't tell at all. I don't have any pic's yet (just got them last Friday), but when I get a chance I will post some, I think they look really nice.
Old 02-22-2002, 10:55 PM
FFEric224's Avatar
Just so I get this right..... Pro Comp 33' tires will fit on stock 17 rims without a lift? With the 7.5 inch rims vs a wider rim, will this make a difference in the way the tire handles on the road? And by going to a wider rim, will this increase the chances of rubbing?
Old 02-23-2002, 12:00 PM
wandell's Avatar
Yes, 305/70s (33x12.50s) will fit fine on the stock 16x7 or 17x7.5 inch rims without any trimming of the lower plastic valance on the front bumper. If you go to 8 or 10 inch wide rims you will have to trim the bumper's valance. This is no big deal, all it takes is about 10 minutes and a sharp pocket knife or razor. As to the difference in handling, I didn't really notice a difference when I swaped my BFGs from my stock rims to my 16x10s. The increased track width may make the truck more stable, but I really didn't notice a difference at stock ride height.
Quick Reply: 33's on stock 17 inch wheels
